Forum: Music discussion
Topic: HELP...
djo10Home userMember since 2007
hi i´am from portugal, i´am sorry for my english
I just want to know, when i´am using the atomixmp3 on the computer, how can i listen the music that i will play next the music that people are listen, only with my phones...so... listen the music that i will mix; to mix without using the eyes but using the ears...
sorry the english!!!
help me!!!
geposted Sun 01 Apr 07 @ 7:49 pm
sbangsPRO InfinityMember since 2004
you need a 4.1 or 5.1 sound card to do this and a full copy of atomix mp3 :)
on the soundconfig choose single card , headphones and main
choose the 4.1/5.1 card and you are good to go :)
geposted Sun 01 Apr 07 @ 8:25 pm
Fantástico! =D
Djo10, és tuga? pa isso é brutal... N m dás o teu mail pa falarmos uma beca sobre a cultura musical do nosso lindo país? ;) Responde p/ aqui q eu vou estar por cá, online. Obrigado
Abraços
Dj Tolentino
geposted Fri 06 Apr 07 @ 9:09 pm
skyfxl.... do you know if the herculos MK2 have that sound card ? 4.1 or 5.1 ? it have !?!?! haven´t ??
geposted Sun 08 Apr 07 @ 5:57 pm
Já tás adicionado! ;) Agora aceita-me no MSN sff: bartasp,hotmail.com
geposted Mon 09 Apr 07 @ 4:52 pm
4.1
geposted Mon 09 Apr 07 @ 11:31 pm
hey man you can find that sound card 5.1 with dell computer company at www.dell.com, i had the same pbm , but when i but the zalman 5.1 sound card it work great, and now i can pre listen to the next song in my headphone when another one is beeing played for the public, good luck , that cost me just $55 good luck
geposted Mon 14 May 07 @ 2:31 pm
also try using the fast track pro from M-Audio, It allows usb connection to DUAL SOUNDCARD OUTPUTS, then you plug those into your mixer and use the cue from the channel on the mixers
geposted Sat 14 Jul 07 @ 3:20 am
dhedheHome userMember since 2007
i have a . virtual software how can i active video mixing
geposted Sun 15 Jul 07 @ 7:03 pm
spinnaJPRO InfinityMember since 2004
R u using the demo trial or full pro version? Pls enter ur serial.
geposted Sun 15 Jul 07 @ 7:37 pm
