Forum: VirtualDJ Skins
Topic: Att: Format
HoffmanPRO InfinityMember since 2006
HI
I use the vmix 5.2 skin.
In the upper part, there is a place (like all skins) to see the video transtion you have selected.
Right now it says Flip3d Transition in the little window.
Sometimes it says Heart if I have that one chosen.
Here is my question...
Some transtion names don't fit in this little window and it scrolls (like Flip 3d Transition).
Is there a way I can edit/shorten the name so it fits in the little window and does not scroll (like heart just sits there)? I also don't want to mess anything up.
Thanks so much.
examples:
I'd like to make these happen
flip3d transition ----> flip3d
thanks for any response.
B
geposted Tue 17 Apr 07 @ 4:57 pm
cstollPRO InfinityMember since 2004
geposted Wed 18 Apr 07 @ 1:28 am
DO you think DJ cell woudl help out since he made most of these transitions?
geposted Wed 18 Apr 07 @ 1:42 am
To be honest, he would most likely even have a better answer. I will reference the other post at the VIP level and see what happens.
btw, to answer your question in the other thread -- been doing well !
cstoll
geposted Wed 18 Apr 07 @ 1:47 am
Thanks.
stay safe.
B
geposted Wed 18 Apr 07 @ 2:57 am
