Hi there!
I just wanted to ask if it's possible to execute pitch reset from an effect plugin?
Why? I've got the DJ Console and want to reset the pitch (slow way) using a button from the console. Using an effect seems the most elegant way to do this.
Greetings,
SvOlli
Greetings,
SvOlli
geposted Wed 29 Sep 04 @ 5:44 pm
A plugin could do it but you don't really need a plugin to do this.
You can easily create a shortcut. This way a slot effect is not lost for it.
With the shortcut you can choose which desk you want to assign with you your key (or the default one).
Clax
Clax
geposted Thu 30 Sep 04 @ 5:13 am
