I am wandering if there is real advantages in getting VDJ 2.0 with the DJ Console.
I guess I can get more effects, ID3 readings (but not writing), additonal sound configuration. What else am I missing that you find really useful in 2.0. Should I keep my money?
Thanks for the advises.
DJ BJ
DJ BJ
geposted Fri 08 Oct 04 @ 4:08 am
Hello,
You can see the difference for the option between each version here: http://www.virtualdj.com/products/comparison.html
and for more detail between the 1.09 and the 2.xx here://www.virtualdj.com/features/history.html
Coyote
Coyote
geposted Fri 08 Oct 04 @ 5:43 am
Thanks.
BTW Version 1.09 and the demo version do not coexist to well together. Because you do not use a seperate folder for the demo installation, I lost all the FX.dll that were working for 1.09 (they were replace with the new versions which does not work in 1.09). Beside now in 1.09 Sample opens the FX window and vice versa! The bad part is that I am unable to open the DJ Console CD to reinstall VDJ. :(
Let me know if you can help.
DJBJ
DJBJ
geposted Fri 08 Oct 04 @ 2:30 pm
bjbladerunner: another great advantage of versions 2.x over 1.09 is the possibility to scratch with the DJConsole. You also have access to advanced sound configuration, and many more features :)
macourteau
macourteau
geposted Fri 08 Oct 04 @ 4:05 pm
I think it is worth it. this program is so cool and you don't want to not be able to down load any updates/fx or samples, you won't be disappointed
geposted Thu 14 Oct 04 @ 1:42 pm
YES!!! i have not looked back!
geposted Fri 15 Oct 04 @ 8:25 am
