i like that skin
geposted Sun 05 Aug 07 @ 7:33 pm
I have just validated the skin.
It is available here for download: http://www.virtualdj.com/addons/skin.html?id=3678
(Pro level only).
(Pro level only).
geposted Mon 06 Aug 07 @ 12:21 am
Jeremk, can you validate that skin too? (CDJ1000MK3 and DJM800 Skin (1680x1050) )!
geposted Mon 06 Aug 07 @ 7:29 am
djjb you have done a good work!!!!
geposted Mon 06 Aug 07 @ 10:29 am
@ djjb ---> Congratulations !
.....But there is no action when I push on the +/- just under the pitch cursor !
geposted Mon 06 Aug 07 @ 12:11 pm
sorry forgot that...
I will change this and update.
geposted Mon 06 Aug 07 @ 6:46 pm
Thx !
geposted Mon 06 Aug 07 @ 7:12 pm
at this time update is done.
geposted Tue 07 Aug 07 @ 8:02 am
... But not again validated ! Waiting for !
geposted Tue 07 Aug 07 @ 8:29 am
Hey, be patient guys :)
Skin updated. Link to skin available in my previous post above.
geposted Tue 07 Aug 07 @ 10:57 pm
the file has wrong fileending . you must rename the .zip to .exe to get it to work
geposted Wed 08 Aug 07 @ 7:10 am
Exactly. you have to rename the file as .exe
Please you adjust this
geposted Wed 08 Aug 07 @ 10:48 am
How to do under VISTA ?
geposted Wed 08 Aug 07 @ 3:27 pm
I think it can by typing .exe bihind your file name and it chances itselfe. For example skin1 > skin1.exe
geposted Wed 08 Aug 07 @ 4:30 pm
Nothing to do !
After rename, I have 4.xx.exe.zip !!
geposted Wed 08 Aug 07 @ 8:38 pm
Windows by default has "Do not show extention for known files" activated.
So it doesnt help that you write ZIP or EXE at end of known files...
Go to "folder options" in Windows, and uncheck the hide extention setting, before you try a rename.
and its EXE not ZIP, for the skin install file
geposted Wed 08 Aug 07 @ 9:57 pm
or maybe someone with the right privileges can fix the installer so it will work for anyone that can download it !
geposted Wed 08 Aug 07 @ 10:50 pm
Has nothing to do with priveleges, but is a bug in certain internet explorers.
geposted Wed 08 Aug 07 @ 11:39 pm
Sorry my bad. I forgot to change the extension from .zip to .exe in the addon manager after adding the automatic installer. Anyway the problem is fixed, and didn't last for too long.
Send me a PM next time for a problem like this, i'll solve it faster as i'll get the information faster :-)
geposted Thu 09 Aug 07 @ 1:56 am
update 12-08-07
scratch is fixed for chan 2
3 options for rhythm-window
geposted Sun 12 Aug 07 @ 6:58 am
