Forum: VirtualDJ Skins
Topic: Skin without wavedisplay?
HannepPRO InfinityMember since 2004
Hi, as mentioned in the threadname, Are there any Skins for vdj without the wavedisplay (the upper window where you "see" the song) coz i want one bad :D
It isnt possible for me to drag vdj towards the top hiding the display :(
Thanks in advance
//Carl Johannes Drakenberg
geposted Thu 26 Jul 07 @ 5:38 pm
JeremKPRO InfinityModeratorMember since 2004
I think VMIX 5 from dj format has that.
Or else you could take your favorite skin and delete the wavedisplay part.
geposted Thu 26 Jul 07 @ 6:15 pm
Mix Lab2 also, soon out... He's working on it right now
It will feature a wave pannel, where you can hide the wave, split the wave, or have dual wave :;)
geposted Thu 26 Jul 07 @ 7:11 pm
ciocePRO InfinityMember since 2004
geposted Thu 26 Jul 07 @ 7:13 pm
Where could i get a hold on this skin in zip format, aka for mac...
Will it disable the display on top or the one next to the song title, the one that looks like the preview on the cdj 1000 that im used to.
Vdj is great for holliday mixing, and the wavedisplay kills my mix because i get obsessed by the visuals.
Skyfxl, do you have it?
If mail it if it isnt to much asked, i would aprieated :D
Best Regards from Carl Johannes Drakenberg.
geposted Thu 26 Jul 07 @ 7:47 pm
sbangsPRO InfinityMember since 2004
its not ready yet if you mean mixlab 2
geposted Fri 27 Jul 07 @ 2:43 am
What a killer skin you got there, could you pm me when its out
Thanks in advance and some fine regards from hangover CJD :D
geposted Sun 29 Jul 07 @ 4:17 pm
