Hi, I'm using VDJ 2.02 now, and want to update to v2.04. The question is, should I installl v2.03 update first before I continue to V2.04? or I can directly install the v2.04 update from my v2.03? Thx before.
geposted Sun 10 Oct 04 @ 2:56 pm
the update works with any version of VirtualDJ 2.
geposted Sun 10 Oct 04 @ 4:56 pm
So just to be clear, does that mean that the latest update always includes the previous updates?
geposted Sun 10 Oct 04 @ 9:45 pm
The current update contains the new .exe file (and maybe other modified files), which replaces the old one, and thus can be installed over any 2.x installation...
macourteau
macourteau
geposted Sun 10 Oct 04 @ 9:46 pm
I used to have samples and loops on my keyboard, but now the keys are not responding. I have gone to keyboard shortcuts to program the keys, but it is not working. What else can I do ?
geposted Mon 11 Oct 04 @ 1:34 am
Your shortcuts.txt has probably been replaced by the update.
-> You have to modify this file to your wishes
-> You have to create a copy of this file (and even you database.xml). In this case you can simply replace these files after an update or a crash.
Clax
Clax
geposted Mon 11 Oct 04 @ 6:09 pm
I had a problem with 2.04, so I deleted it and installed 2.01 and installed immediately to 2.04 and it worked fine.
geposted Tue 12 Oct 04 @ 1:19 am
