Forum: Music discussion
Topic: Locking deck A + B
Can deck A and deck B of Virtual DJ both be cue-ed by giving them both a cue-point so that they are locked and stay in sync while using just
one of the decks to jog backward or forward (or click just 1 play-button to start both deck A and B at the same time) ? This is more an analog
editing tool, but can be very handy for mix or editing audio or video.
geposted Mon 03 Sep 07 @ 12:41 pm
Pls dont double post.. u already have ur answer at the general forum.
Sorry about posting this topic at more than 1 forum. As not everyone is reading each forum I thought that posting it to the mainforums could be handy.
no prob.. anyway next time just post in one forum where it is appropriate, ppl will read each forum im sure:).. This is to act to not create confusion.. for answer n make unnessary thread that already existed:)
Isn't it handy to add the same topic to an other language-forum as well? For example: to add the same topic to both the General and Dutch-forum for Dutch users not well known with the English language?
yes that will do, but not to in the same language:)
VDJ Staff,
Can this topic please be closed and removed on this forum. It is already been posted to another forum. To avoid confusing closing and removing the topic on this forum would be appreciated (also by me).
By the way, when cosed or removed this thread can be found at the General forum and New wishes forum as thread "New Mixing Tools as follow:
(This could be a description how to set the new features:)
- New Lock-function:
Give deck A and deck B at any point both a cue-point and then lock or sync both decks (NOT like the lock or sync for BPM!) so that they response exactly the same while using just 1 of the decks to jog backward or forward. While locked they will also start both at the same time by using just 1 Play-button.
- New Go-To-function:
Give deck A and deck B at any point both a cue-point. Then give just 1 deck (either Deck A or B) at another point a second cue-point. If now the New Go-To-function is used the deck WITHOUT second cue-point will automaticly go to the second cue-point which is set for the other deck.
NOTE: With this type of GO-TO feature the TIME-FRAME between 2 cue-points of a deck are used to automaticly find the second cue-point for a deck with just 1
cue-point to set the same time-frame for both decks.
For both functions the interface should contain some new extra buttons and displays, as everything should be within reach and view.
Actually those functions are just an basic analog editing tool but can be used for so much more. Integrating it in Virtual DJ gives users an extra mixing tool and can
save time. It just would make things even easier.
As they say: the only limit is your own creativity!
I apologize for the fact that this subject now is on more then 1 forum. Closing and removing it here would be the best thing to do :-)
