Forum: Old versions
Topic: Pitch & tempo
zipaHome userMember since 2007
I’m using VDJ 2.06. In this version it is possible to change music tempo with pitch preserving. In your latest version (5.0 trial for test) I’m not able to find this feature, witch changing tempo the pitch is changed too. Can you tell me the way to change configuration for return to previous behavior?
geposted Mon 24 Sep 07 @ 1:52 pm
Please buyh the product if you want help!
geposted Tue 25 Sep 07 @ 3:48 pm
I have a licence for the old version and I am going to buy new version, I need it for my business. So I am trying the new version, but this feature I am not able to find. Because it is really important for me, I am looking for more information. So in this case for me will be enough you will confirm it is possible to set.
geposted Thu 27 Sep 07 @ 8:26 am
spinnaJPRO InfinityMember since 2004
pls register in ur modify your profiile.. thks n btw it is possible..
geposted Thu 27 Sep 07 @ 9:44 am
sbangsPRO InfinityMember since 2004
if you have a valid pro serial you are entitled to the update free
please add your serial
hope to see you as a pro user soon:)
geposted Thu 27 Sep 07 @ 8:03 pm
Hi this is arcoirismusical, in this new version 5.0 I can't find the tempo, I tried differeent settings possibles, but I can't made it to work, can you let me know how to set it properly. please
geposted Sat 29 Sep 07 @ 5:41 pm
click keylock:) Ur pitch will stay even when the tempo is stretch.
geposted Sat 29 Sep 07 @ 8:34 pm
DJ-ALFPRO InfinityModeratorMember since 2005
Yes, and the Keylock is right below pitch fader with Lock icon ;)
geposted Mon 01 Oct 07 @ 4:55 pm
Does anyone knows how to make it that when I spin the jog wheel to correct the song for a second, it won't change the pitch too?
geposted Fri 15 Jul 11 @ 5:10 pm
