Forum: Wishes and new features
Topic: Auto Cue to first cue..
it would b great that while loading the next song it auto cues on the first beat of the song or lyrics without any silence..
head phone volume should b boosted coz the setting for the 4.1 sound card makes the rear sound low...
like traktor dj the option to change the rear and front sound outputs is possible...
and since many external mixers have a pgm in their mixer to hear the mix in the head phones without having to remove it.. even traktor dj has it..pleade it will be helpful.
geposted Fri 29 Oct 04 @ 6:59 am
djjbPRO InfinityMember since 2004
changing the outputs is only for the full vdj
geposted Fri 29 Oct 04 @ 8:27 am
yeah its only the full version where the outputs can b set but i hav the full version even if i'm not a licensed user..got it from friend...
thx..
geposted Sun 31 Oct 04 @ 5:09 am
hhmmm, your friend may not distribute this software. If you got it from a friend, then it is NOT the full legal version!
Also, if your friend is a "registered" user, then his status and serial number are also at risk.
geposted Mon 01 Nov 04 @ 3:09 pm
