Topic: Using loop record.
Hi every1.
When using loop record i find that sometimes the max volume isnt loud enough when i play back during a mix. Ive turned dthe gain up on the songs and recorded but that doesnt work.
Any way out of this1?
geposted Sun 21 Oct 07 @ 12:38 pm
B-u-m-p
There better not be a really easy answer to this one.... i dont think there is.
what i do if encounter this, i would record it in sound forge or any audio editing program, edit it then put it in the samples for looping.
not a bad idea, i will consider that if i cant do it in virtual dj, i say its the only way. cheers.
i looked in the manual and i couldnt find anything. dam why cant you record loops and have the sound recorded, be controlled by the gain as well!
The answer is in the saound card you are using. If you get the gigaport ag soundcard you can use the 3 line out setup.
line 1= deck A
line 2= deck B
line 3= samples
then you will be able to play the samples on a deperate line with its own gain and eq (on the external mixer)
