hey!
the size of the letters (alphabets) on my tracks playlist on Virtual DJ 2.0 is too small....how do i make it more larger and more visible?
ciao!
ciao!
geposted Fri 05 Nov 04 @ 6:49 pm
open the xml file of the skin you use in notepad.
and change the pxl of the font.
geposted Fri 05 Nov 04 @ 7:07 pm
I had the same problem and it was simple fix. The skin I was using wasn't matched with the display setting on the computer. 1024X768 or 800x600 for both for instance. The two need to be matched. The other suggestion probably works too. This is how I fixed it.
geposted Tue 16 Nov 04 @ 3:12 pm
