On some of my music, there is an * behind the bpm count and i wanted to know what this means?
geposted Mon 14 Jul 03 @ 7:34 am
Does anybody else have a * behind there bpm count?
geposted Mon 14 Jul 03 @ 8:41 am
This means that the song can be successfully beatlocked.
geposted Mon 14 Jul 03 @ 9:31 am
Aight thx homeboy, you a true homeboy
geposted Mon 14 Jul 03 @ 11:33 am
Not exactly, the * means that the CBG is correctly defined on the song (ie that Virtual DJ has found a good pattern and has set correctly BPM and phase informations)
This feature means that in automix mode, the song should be mixed on tempo with another "*"-rated song
You can see a "!" if the song has a pop or noizes, or if you have a cut (like a damaged mp3 file for example)
geposted Mon 14 Jul 03 @ 6:05 pm
Thxs for the clarification Yan I wasn't aware of that ;)
geposted Tue 15 Jul 03 @ 9:20 am
