Forum: VirtualDJ Skins
Topic: I'm in clipmask hell....
djnutzPRO InfinityMember since 2006
I'm having some really frustrating issues with a skin. I have some buttons that fall inside the clipmask for the platter. Is there anyway to have the platter spin and make the buttons operate?
geposted Wed 12 Dec 07 @ 6:04 pm
erxonPRO InfinityMember since 2003
Clipmask "can" overlap with buttons, but when the platter image will be spinning, everything that is over this clipmask will start flickering (blinking) - rendering issue. I suggest you avoid overlapping the elements.
geposted Thu 13 Dec 07 @ 1:04 am
listen2PRO InfinityMember since 2005
It depends on your design but the clipmask has to be identical to the area you want covered. So if there are buttons inside deck that you dont want masked you will have to cut out the area where your buttons are.
geposted Mon 17 Dec 07 @ 11:31 am
