Hey guys,
I just got an M-Audio X Session Pro Mixer for X-mas. I checked on the Virtual DJ Site, and it says that this mixer is perfect to use with Virtual DJ. For now, I do not have turntables, so what I really want to do is use this mixer with Virtual Dj in order to mix mp3's on the program. My problem is, I cannot get the mixer to synch with virtual DJ. Do I need a sound card or something to do this? I did not think I would, as the mixer is USB and has no RCA inputs for a serato/asio type sound card. I am very new to this, and the reason I got the mixer was because I saw on the site that it was a perfect mixer to use with Virtual DJ. All I want to be able to do is cue in headphones, and to use the M-Audio Mixer to control the fader and stuff on the Virtual DJ program. Can anyone help me out? Thanks in advance.
geposted Wed 26 Dec 07 @ 2:29 pm
you need to map it in VDJ keyboard/midi mapper tab, in settings.
Or, if you buy a licence, you can download already made mappers from this site
geposted Wed 26 Dec 07 @ 2:46 pm
Norway is right on as usual
I have X session on one of My newer rigs and I like it
I had to setup the midi mapping (sounds hard but it's real easy )
Hook up ,go into config ,move the pad or slider and see what note you are touching ,then assign the function you
wish to that note ,save etc.,,,,,kinda cool *s*
and please buy the full ver ,money well spent ,,And as You can see ,support is Awesome
Thanks
Best to You
Scott
Thanks
Best to You
Scott
geposted Sun 06 Jan 08 @ 10:24 pm
