Forum: Old versions
Topic: please help!!! set up djm800, cdj1000 mk3, vdj, maya44 mix video
please explain step by step cause i'm not good much in english.
now i use maya44 cdj1000 mk3 djm800, timecode cds and VDJ mix my tune it's work fine but i want to use midi of djm800 so i bought midi dongle usb. what should i do next in correct way.
i just wanna use see when i crossfade my djm800 and VDJ move like i move. cause now i wanna mix video.
thank you
geposted Wed 16 Jan 08 @ 12:09 pm
follow these steps
go to config
remote control
Midi, activate,
config, add
mixer, crossfade
move the cross fader on you DJM 800
Don't forget to link crossfaders if you want to mix audio+video at a time.
i have move cross fader but virtual dj know nothing just like it not recognize. i try to press ok when i add mixer but it shows nothing.
+++ how to link video and audio together?
thank you
is it about i use vdj5 or i need vdjpro?
again...my screen comes up with "autolearn" in the box below is there something wrong?
How do you configure this in vdj 6.1
Cracked version of VDJ causes problems. You may want to try the free demo of VDJ 6.0.2 and your problems may resolve themselves.
Hope to see you soon as a registered Pro VDJ user.
Good luck.
Good luck.
Please disregard this post as I see it is an old thread. However if this applies to anyone in this situation, it's still good advice.
