hi
im tryin to figure out how to make a dj intro like "ur in the mix wit dj so n so"
my dj name is DJ VIC
i made my own usin my mic and stuff but i dont like the way it is is there anther way i can make one?
geposted Mon 28 Jan 08 @ 6:14 pm
RCdude wrote :
hi
We get AMaHM to threaten voice over people...
But you can try Radio Daddy...google it.
geposted Mon 28 Jan 08 @ 6:26 pm
Get one of your friends to record it for you lol...
You can get the microsoft word voice relay to say what you have typed out in text. It will have the electronic sam sound.
geposted Mon 28 Jan 08 @ 7:41 pm
they use audio editing soft and tools, is easy but you need the tools, is a multi track virtual mix with all kind of loops sounds and effects
geposted Mon 28 Jan 08 @ 11:13 pm
I made a few quick promos with the free Audacity sound editor. They came out okay for a quick, do-it-yourself type of thing. I'm sure if I spent enough time on editing and tidying up, the program would handle it. I've even made ringtones with the rascal!! For effects, etc., you just keep saving your work as you go and add to it what you will, by laying down more tracks alongside the original. Pretty powerful for a freebie.
BTW, you can also have a professional version done by the Source DJ Music Supply, at www.thesourceformusic.com. I think it's under "DJ Drops."
geposted Tue 29 Jan 08 @ 12:49 am
Hii
Im trying make a dj intro like saying you are now in the mix with ___
My Name Is D.J Sanders
you think you could help me make it
geposted Fri 19 Apr 13 @ 1:09 am
Or the simple way is to give xtendamix $150 and they will custom make one for you including video.
geposted Fri 19 Apr 13 @ 2:39 am
The Wigman also does a good job for a bit less money. You can also chose from a selection of "packs" or have custom drops made.
DJ Drops By Wigman
Cheers,
Roy
DJ Drops By Wigman
Cheers,
Roy
geposted Fri 19 Apr 13 @ 7:20 am
Find a friend that has a great speaking voice and have him say the things you want in a radio announcer style, any audio editor will work but if you have access to a daw like cubase pro tools cakewalk then just do your mix and effects..bam...
geposted Fri 19 Apr 13 @ 9:21 am
geposted Fri 19 Apr 13 @ 9:23 am
you could use a text to speech converter to create your own & experiment with pitch , phrasing , male , female voices or accents. Then record or export the results.. You could also overdub music or sound effects so your intro has a greater impact...
Here's an example... ..The jingle has a high frequency so it cuts through typical audio bandwidths.
http://www75.zippyshare.com/v/43165946/file.html
Element.
Element.
geposted Fri 19 Apr 13 @ 7:26 pm
Hello, on voice drops and other intros..most companies charge a fee to produce them, especially for custom made versions.
Here's the web link: http://www.musicradiocreative.com that will let you download a sample of free radio drops, all you do is just sign up with your email address to receive a download link, I found a lot of useful drops that can be edited to your liking, you just need a "wave editor" software like what comes in the Nero Burning Rom software to edit the drops since the samples are recorded in one long package.
Best of wishes, Jeff :)
geposted Sun 21 Apr 13 @ 5:37 am
i like the wigmans best
geposted Sun 21 Apr 13 @ 6:19 pm
Try Mitch Craig, this guys voice is famous. He is retired but still does drops, it was very affordable when I got my drops years ago. Here is his website. www.mitchcraig.com.
geposted Sun 21 Apr 13 @ 9:22 pm
