Hey! I absolutely love the new Mixlab skin,but could you please get rid of the batman picture in the background? It looks cheezy, and it's distracting.. could you please post a solid black version with the regular font also? the new font is too fat for my liking... just an alternate version? leave them both up like you usually do...
Thanks for the stellar work man!
geposted Fri 15 Feb 08 @ 10:03 pm
also, in the mode with the wide screen video view, the song titles and bpm don't show up... could you make that show in both views? the space is there for it, but it's blank.. Thanks again...
geposted Fri 15 Feb 08 @ 10:07 pm
Please use the dedicated topic
http://www.virtualdj.com/forums/84324/Skins/Mix_Lab_V3_0_RC2_Testing_-_13_2_2008.html
geposted Sat 16 Feb 08 @ 5:48 am
Steve, you can fix the "batman problem" just by opening up the skin in windows paint. just cut it out and fill it in with black. it takes a whole 10 seconds
geposted Sat 16 Feb 08 @ 9:36 am
would that mean it will be simple enough to add our own graghic in place of the batman icon? or can we only blank it out
Tayla
Tayla
geposted Sat 16 Feb 08 @ 7:35 pm
yes.. it's that easy
geposted Sun 17 Feb 08 @ 2:11 am
@ mad maxx
thanks for the info
@ format
would you mind if i kept this on your skin or revert back to using yours only, thanks
[IMG]http://img220.imageshack.us/img220/2968/vdjpic2fv7.th.png" border="0">[/img]
Tayla
thanks for the info
@ format
Tayla
geposted Sun 17 Feb 08 @ 12:55 pm
thankyou,
as usual your skins are the dogs bollocks, still mean what i said above this or 1.3 should be the default skin and that's not showing any disrespect to the other skinners hope you don't think that guys, just my taste in choice
Tayla
Tayla
geposted Sun 17 Feb 08 @ 6:04 pm
Yeah I think that you really deserve the "official VDJ skinner" title ! Your skins are awesome...should be the default VDJ skins ! :)
geposted Mon 18 Feb 08 @ 7:33 pm
mix lab 3.0
geposted Wed 16 May 18 @ 2:24 pm
Locked, 10 year old thread.
geposted Thu 17 May 18 @ 9:31 am
