Forum: Dutch Forum
Topic: compatibiliteit dj console versterker?
loubeHome userMember since 2004
Hallo iedereen,
volgend weekend gaan ik en een vriend met onze dj console draaien op een fuif (Art of Trance), maar we beginnen ons nu toch vragen te stellen over de compatibiliteit van deze console met eventuele versterkers, omda we op dit forum vaak klachten horen over dergelijke zaken. Onze versterker is een 1400LX 2 canal 2x700W, maar die kunnen we nu nog niet testen, daarom dat ik het op voorhand vraag aan jullie :)
dit is de uitleg op de site:
The use of Modern High Speed Mosfet Transistors provide not only a great sound but are welproven to be one of the most reliable power sources in todays Amplifier Technology. To cape with the demands of modern music, all of the Amplifiers in the range have built in Crossover Filters, enabling you to run the Amplifiers "Full Range" or at your selected Crossover frequency, so there is no need for an external Actice Crossover. These are just a few of many great features on the LX Series, so read on and find out why Palmer Amplifiers are the perfect workhorse for your Sound System.
Special features:
- Integrated Clip Limiter to prevent Output Clipping
- "Soft Start" on power up to protect Speakers from "Thumping"
- "Power down" mode (incase of overheating, this function reduces the
ower rather than a complete shut down)
- 2 stage temperature controlled fan cooling
- "Speakon" Outputs, plus an extra "Speakon" Output for "Bridge" mode
- Balanced XLR/Jack Inputs (spare acts as "thru" for direct Amplifier linking)
- Variable Hi/Lo pass Filters on each channel from 75 Hz to 1200 Hz
- 2 ohm capability in "Stereo" and 4 ohms in "Bridge" on LX 1400 / LX2000
- Rack mounting brackets on front and rear panels
- Rugged Steel Chassis in attractive "Gun Metal" finish
Dimensions (WxHxD in mm): 483 x 132 x 420, Weight: 20 kg
Zou dit enige problemen kunnen geven bij het aansluiten met onze Dj Console, of zijn er specifieke punten waar we op moeten letten? We gebruiken VDJ (de versie dat meegeleverd was bij de console)
Alvast bedankt!
geposted Mon 06 Dec 04 @ 10:33 am
Ik ben van plan de officiële VDJ2 te kopen omdat de bijgeleverde versie - bij uw dj console - blijkbaar maar een soort demo is ofzoiets (iets wat ik tot op de dag van vandaag nog niet wist :s), waarmee bepaalde functies niet mogelijk zijn?! spijtig genoeg werkt de link om het te kopen niet, ik krijg steeds de melding: error in purchase security
geposted Mon 06 Dec 04 @ 12:54 pm
djjbPRO InfinityMember since 2004
loube ik weet niet hoe het kan maar hier werkt die link wel.
geposted Sun 12 Dec 04 @ 12:21 am
ok het werkt perfect! feestje was een succes met de dj console!!
Binnenkort nog eentje zou ik zeggen ;)
geposted Mon 13 Dec 04 @ 3:30 am
