Is there a way to setup a cue on track1 and a cue on track2 and have VDJ cut from track1 when it gets to the cue and play track2 from the cue. Also fading could be quite useful.
I know about putting a cue in track2 and hitting automix at the corect point but this relies on my pressing it at exaxtly the right point!
Many thank in advance!
geposted Wed 29 Dec 04 @ 9:14 am
You adjust the "in" and "out" points on each track ... like cue points.
Right-click on a track when loaded or click on the "BPM" button (avaibale on a few skins) then select "adjust automix" and then define "in" and "out".
When automix is on VDJ will stop the current track at its "out" point and play the next one at its "in" point.
You can select what kind of mix is allowed with these tracks.
geposted Wed 29 Dec 04 @ 10:50 am
