Forum: Old versions
Topic: How to set up Korg Zero 4 with timecode (CD)
How to set up timecode with Korg Zero 4 and 2 x Denon S1000 cd players.
I,ve tried, but the music are to slow...........
THANKS!!!!!!
Johnny
geposted Sun 18 May 08 @ 1:04 pm
THANKS!!!!!!
Johnny
Hi Johnny,
I´m using Korg Zero 4 with Timecode Vinyl so I can´t directly help but I´ll give it a try.
So you say music is playing too slow. So then timecode is working with both players? You get a signal in the "Timecode configuration window" for both players?
Have you tried the following in the "Timecode configuration window":
1. Under "Engine" ---> "CD" is checked?
2. Have you tried to change speed from 33rpm to 45rpm?
Another thing what comes into my mind. Have the CD-Players any function that could cause the slow music? Like a button for master-tempo on the CD-Players?
Try to give some more information. And maybe someone else who uses the Korg Zero with CD-Players can give you a hint.
Best regards
geposted Fri 23 May 08 @ 2:37 am
Thanks!!
I,ll try
Johnny
geposted Sat 24 May 08 @ 12:41 pm
