can any one give me plugin and extra sounds and i cant record to mp3 files
geposted Wed 07 Sep 05 @ 7:05 pm
why do you think anyone will give you anything ???
Did you try to search ???
If yes, you could easily find a message that Plugins are downloadable only by FULL USERS.
so if you buy this software you will get access.
geposted Wed 07 Sep 05 @ 8:38 pm
what about the dac3? Is this controller really compatible with VDJ like the dac2? and have we to use it with a specific plugin ?
geposted Sun 25 Sep 05 @ 6:49 pm
OK, I quess I'm stupid I"ve downloaded the DMC/DAC mapper plug in and it's in my effects folder what do I after that to map my DAC?
geposted Sun 02 Oct 05 @ 11:42 pm
I don't have the DAC but i don't think that the .dll has to be in the effects folder. I would say in the VDJ root folder easily.
If someone could confirm?
geposted Mon 03 Oct 05 @ 8:08 pm
Correct. I guess it is explained in the readme..
geposted Mon 03 Oct 05 @ 10:17 pm
Thanx
geposted Sun 16 Oct 05 @ 5:57 pm
Does the plugin still work with this latest version of vdj (3.2)?
geposted Fri 25 Nov 05 @ 1:17 pm
it works for me without problems
geposted Sun 27 Nov 05 @ 11:38 am
geposted Tue 06 Dec 05 @ 1:06 am
