Is there anyway I can adjust virtual DJ to scan each and every mp3 I have for BPM? Right now I have to sit here and scan each one manually and it would be nice to set up VDJ to auto scan my mp3's over night so they will be finished scanning by the next morning.
I'm using Cue LE 4 so is this a feature available in the full version of the software?
geposted Tue 27 May 08 @ 2:45 am
just highlight all of your tracks top to bottom, right click on browser and select analize tracks, i normally select other music... hope that helps
Tayla
Tayla
geposted Tue 27 May 08 @ 2:53 am
This is way easier. Thank you so much. I can't believe I've been doing it the hard way for so long.
geposted Tue 27 May 08 @ 3:13 am
no probs mate, of course you can do the same just for certain sections of your files if you want.... glad i could help
geposted Tue 27 May 08 @ 4:39 am
If you have a folder setup with all your MP3/Videos, you can also right click on it from the brower and choose Scan For BPMs
geposted Tue 27 May 08 @ 7:46 pm
hey but every time i try highlighting the tracks it drags the song.how do you actually higlight all songs?weird
hope u can help.
hope u can help.
geposted Tue 03 Jun 08 @ 1:46 pm
hope u can help.
hope u can help.
click on any of the songs.
and press CTRL and A at the same time......that will highlight all songs
and then u right click and analyze bpm ..
geposted Tue 03 Jun 08 @ 1:56 pm
thanks man.
appreciate!
appreciate!
geposted Thu 05 Jun 08 @ 2:28 am
Is it possible to scan autogains only? My BPM:s are fine. I don't want to touch em. But I just noticed that VDJ 5.1 rescans autogains for tracks i haven't played on 5.1 (but played on 5.0). This causes sometimes very loud and distorted sound during scan if you start to play the track immediately.
It's very annoying if during gig you start to play something you haven't played since version 5.0.
Thanks for the great update anyway :)
geposted Thu 05 Jun 08 @ 5:12 am
Your best bet is to scan your tracks ahead of time as described above to avoid gain problems, even if your BPMs are okay. I don't know of a way to scan only for gain. All of my tracks have been normalized, but I had a little trouble with gain changes on load before I did this. If you don't want to rescan everything, just wait until the track is fully loaded before playing it, which has the same effect.
geposted Thu 05 Jun 08 @ 2:57 pm
hope u can help.
hope u can help.
Hi, could you tell me how I would do this on a Mac?
Thanks
geposted Tue 21 Jun 11 @ 3:30 pm
highlight the containging folder or drive, right click, scan for bpm's
geposted Wed 22 Jun 11 @ 5:43 pm
when i right click on my mac it unselects all and does not scans the BPM for any song. HELP!!!!!!!
geposted Mon 30 Jul 12 @ 12:52 pm
how do i scan my songs for bpm on the virtual dj 6.0
geposted Mon 03 Feb 14 @ 1:12 am
Just rightclick a folder and select "scan for bpm" ?!
geposted Mon 03 Feb 14 @ 3:53 am
You should update at least to the latest version 6.xx available in your Download Center.
As i remember there where a issue with broken Databases in the early version 6.0.
Greets, Heiko
Greets, Heiko
geposted Mon 03 Feb 14 @ 3:55 am
If I scan for BPM on my Imac, will the BPM be shown when using my MACBOOK? or does it have to be done specifically with the machine that one uses? Thanks for the help
geposted Wed 02 Mar 16 @ 8:11 pm
If both Macs have identical folder structure regarding your Music Library, then all u need is to transfer (copy) the database.xml file(s) to your new computer.
BPM, Hotcues, Key etc are stored in the VirtualDJ Database.
some useful info here https://virtualdj.com/wiki/VirtualDJ8_Backup%20Database_.html
geposted Wed 02 Mar 16 @ 8:33 pm
Tayla
Tayla
Hi Tayla,
you are the best! Thank you!
geposted Fri 28 Feb 20 @ 6:21 pm
