Im using a maya 44 sound card and was wondering if the Axis 9 decks from numark will work good with Cue. Also which time coded disc do i use for this setup?
geposted Fri 30 May 08 @ 12:38 pm
Yes, these CD players should work great with timecode CD's. I have used them before in the past.
You will need to download the timecode file and burn it to a couple of CD's:
http://www.virtualdj.com/products/timecode/cd.html
Try the consumer grade first, and if you have difficulties getting a 100% timecode signal, try the pro grade.
geposted Fri 30 May 08 @ 1:31 pm
The axis 9 should give you great results with the TCD , we have done alot of testing with them.
geposted Fri 30 May 08 @ 2:47 pm
Ok good i will try them out soon and see how stable and accurate it is cause my numark cdn 88 don't work good with cue at all !!
geposted Sat 31 May 08 @ 9:20 pm
They where not intended for that purpose.
geposted Sun 01 Jun 08 @ 6:50 am
So what are you saying that Axis 9 is not made for hand in hand use with cue? Please tell me a list of decks that will work perfect with cue. Right now i'm using a maya 44 soundcard and i already downloaded both versions of the time coded disc so no need to buy the virtual vinyl soundcard like everyone at numark says i need. So far i got everything i need i just need to know some good cd decks thats compatible with the program!!
geposted Sun 01 Jun 08 @ 7:17 am
What Sky was saying was that your old Numark cdn 88, weren't made for timecode use, not your Axis 9, they will be fine
geposted Sun 01 Jun 08 @ 7:23 am
Ok thanks.
geposted Sun 01 Jun 08 @ 8:57 am
If you use CDN-88, you may want to consider the Numark DMC-2 - That's a dedicated controller for VDJ and is very similar in layout to the CDN-88.
geposted Sun 01 Jun 08 @ 2:49 pm
Right now im using the total control but i cant scratch like i want too thats why i want to upgrade my decks to something like the pioneer cdj 600's or 400's or maybe even the denon s3500's i was told that cue works flawless with these decks cause they are midi players!!
geposted Sun 01 Jun 08 @ 5:15 pm
Indeed , cheers Jimmy.
geposted Mon 02 Jun 08 @ 2:12 am
It currently supports them as time code players , and them via general midi control.
Hid control of the CDJ 400 and more Denon units , is hopped for the next update of cue.
geposted Mon 02 Jun 08 @ 2:17 am
Ok thanks i will just wait and see what will be the best option and the most reliable!!
geposted Mon 02 Jun 08 @ 9:45 am
im 13 years old and i am planning on buying the numark axis 9 as timecodes.
geposted Thu 10 Mar 11 @ 1:40 pm
