Please can someone make a mapper for the Denon DN-S1200? I don' t have a clue how to make a mapper for Virtual DJ Mac nor Window.
This Is the link for the MIDI Protocol: http://www.denondj.com/admin/assetmanager/files/DataFile.asp?assetid=226&assettype=Owners%20Manuals
geposted Fri 20 Jun 08 @ 1:24 am
Well first it has to be Natively support for a mapper to be created. Since it currently is not natively supported, you will need to use the MIDI interface from the Remote control tab and assign the MIDI notes/codes to VirtualDJ actions.
geposted Fri 20 Jun 08 @ 5:35 am
cstoll, "you will need to use the MIDI interface from the Remote control tab and assign the MIDI notes/codes to VirtualDJ actions."
How do you do the above? Can I get a qick explaation on how to do this?
geposted Fri 20 Jun 08 @ 7:12 am
It's the same as setting a keyboard shortcut. The difference is in that you press the button on the midi device and assign the action. Follow the same instructions in the manual on keyboard shortcuts.
geposted Sun 22 Jun 08 @ 10:04 pm
Cstoll, I already tried It. Jogwheel still not working.
The buttons are already mapped from the mapper the denon rep posted here on Virtual DJ site.
It' s the jogwheel that Is not mappedout.
geposted Mon 23 Jun 08 @ 11:33 am
Please see your other thread for info on mapping the jogwheel:
http://www.virtualdj.com/forums/92007/Hardware_Technical_Support/Midi_Mapper_for_denon_DN-S1200.html
geposted Mon 23 Jun 08 @ 1:09 pm
