Hi All,
I've found numerous posts about how to fix this issue, unfortunately, none seem to be working for me. Let me please give you some information and hopefully someone can figure this out cause i'm stumped....
Current Equipment:
Numark Virtual Vinyl
CD players & Mixer
Laptop running XP
Numark Que (Similar to Virtual DJ, Atomix MP3, etc)
My current config is:
Input: Timecoded (CDs)
Output: External Mixer
Sound Card: Numark Virtual Vinyl
Originally I had this setup and I initially ran the program with no problem, but then after I shutdown the laptop and returned an hour later, I had the following popup box appear when I tried to "Auto-Config" the Timecoded CD's:
"Error in the ASIO sound driver"
After reading many forums and trying to fix it, i'm still having issues, what i've tried to do is the following:
- Restart Laptop (No change)
- Restart Laptop with USB unplugged, plugged USB in then launched Que (No change)
- Unplug and plug USB cable while being in Que (No change)
- Reinstall Que (No change)
- Going to config, changing the sound card to ASIO sound card, then changing it back to the Virtual Vinyl (No ASIO sound card to select, was forced back to selecting Virtual Vinyl)
- Going to Start > Control Panel > Sounds > Changing sound card (Nothing there to change it to)
I'm considering to trial ASIO4All but would prefer not to.
If anyone could help it would be great, I got a party in 2 weeks and would love to have this up and running by then.
Raef
Current Equipment:
CD players & Mixer
Laptop running XP
Raef
geposted Thu 03 Jul 08 @ 4:49 pm
I don't have Cue but the error messages in VirtualDJ are very generic. Your problem is not with VirtualDJ but your soundcard not being detected, or it is not in ASIO mode / already in use etc. Does the soundcard have a control panel and if so are you able to check whether it is configured correctly? One frustrating thing about Windows is that USB devices install themselves again every time you change your USB port. Although probably not an issue, make sure the soundcard is connected to the port you used when you know it worked. You can also check whether the device is working properly in Device Manager.
geposted Thu 03 Jul 08 @ 4:54 pm
As Andrew87 said, VV can't find the sound input so it's something linked to the drivers of your sound card. Install them again then reboot.
(If it doesn't work, go to the Info panel in the config and click on the button to reset to the factory settings)
geposted Thu 03 Jul 08 @ 5:27 pm
Thanx Andrew and DJCel, I got my cousin coming over after work today to have a look at it all, I hope this fixes the issue, if not, ill keep u guys updated.... anything else we should be looking out for when we check the sound card tonight? will Asio4all help? also, will this issue happen often if i switch between usb ports?
geposted Thu 03 Jul 08 @ 10:20 pm
Don´t try Asio4all. Use the driver that came with the Virtual Vinyl Souncard. And one last thing --> Never switch the USB port after you have installed the soundcard. Always use the same port you installed the soundcard first!!
geposted Fri 04 Jul 08 @ 6:21 am
razorraef wrote :
Hi All,
Current Equipment:
CD players & Mixer
Laptop running XP
Raef
Current Equipment:
CD players & Mixer
Laptop running XP
Raef
Please email me and i can provide you with an alternative driver file.
sbangs[at]numark[dot]com
You cannot use asio for all with this card as it bypasses alot of the windows sound systems.
I would advise you to do a total uninstall of the software and reinstall using the latest version of 5 from Numark.com if you do not wish to register your purchase here yet.
Could you please take a screenshot of your timecode signal?
Which Cd players are you using?
Best Regards
__________________
Simon Bangs
Computer DJ/VJ product Specialist.
Numark Alesis Europe
geposted Sun 06 Jul 08 @ 7:47 am
skyfxl wrote :
[quote=razorraef]Could you please take a screenshot of your timecode signal?
The software wouldn't have a signal if it can't find an asio device? Checking whether Windows has detected the soundcard in device manager would be a good first step. Does the VV souncard have any status monitoring / power leds?
geposted Sun 06 Jul 08 @ 4:46 pm
Not always the message can also be displayed as an error.
Please right click on the virtual vinyl card in device manager if present , and choose uninstall.
If it was not pressent and once you have uninstalled please insert your VV disk find the driver folder right click on Virtual Vinyl .INF and choose install.
Best Regards
__________________
Simon Bangs
geposted Mon 07 Jul 08 @ 12:58 pm
could anyone PLEASE tell me where i can get a good driver that does work with virtual dj?
everytime i set the input to single timecode the ''soundcard(s)'' automaticly jumps to''asio driver and that also is the only option,that splits in 1 audio 8 DJ 2: MP4 driver 3: SL 1 driver 4: TTM 57SL driver (what the hell is the difference?)
but if i select one of those 4 (doesn't matter wich) i get the error ''error in the ASIO sound driver'' and that causes that i can load tracks to the decks but the sound won't start to play, the stutter button lights up but the music doesn't play/start
geposted Sun 05 Apr 09 @ 1:11 pm
Stefanmplayer, I feel you. I have exactly the same problem. Using Windows 7, Virtual DJ V5.2.1 and Hercules RMX - everything loads up and console lights up except "Error in ASIO Sound Driver" comes up. I can move the sliders and even load music but it just won't play. The technical feedback from Hercules is that they have not yet got compatibility for Windows 7 but that has been disputed by some as Windows 7 is essentially Vista based.
Somebody help as I have a gig tonight in Kenya and it is driving me barmy!!!! Cheers.
geposted Fri 01 May 09 @ 12:02 am
stefanmplayer and D-lite, I got the same problem...
geposted Sat 16 May 09 @ 8:12 am
I find that when you get that error message close out of Cue, unplug the usb cord of your audio interface, then power off your cdj's and mixer...In this order
1. plug in the usb cord of your audio interface into your laptop
2. power on your mixer
3. power on your cdj's or turntables
4. open up cue
5. then try to configure, keeping in mind if you are using turntables have the timecodes playing
and you should not see that message again. I found this trick in a post and it has worked for me. It is very particular as to the order that you power up your equipment.
Hope it helps you
4. open up cue
Hope it helps you
geposted Mon 18 May 09 @ 1:58 pm
To get rid of the error reading ASIO load VDJ click on the cofig tab.Then go to sound setup and click on the one that says ASIO card and change it to 6.1 and there you have it good or what it took me the whole of 5mins to sort it and am new at this lol
geposted Wed 22 Jul 09 @ 3:35 pm
However, you need ASIO to use TCD.
geposted Wed 22 Jul 09 @ 11:07 pm
Scusate, provo a collegare il mio cdj400 ma mi compare questo scritta: Error in the ASIO sound driver
Cosa vuol dire e soprattutto cosa devo fare per elimarlo?
Vorrei avere un aiutino una piccola guida su come far funzionare virtual dj pro con i cdj400
Grazie Ivano ( Yoda DJ :-) )
geposted Mon 14 Mar 11 @ 2:48 pm
i am trying to use dj io with my virtual dj and it saying Error in the ASIO sound driver,i have A dance to dj and i need help!
geposted Mon 21 Mar 11 @ 6:55 pm
Go to CONFIG -> Sound Setup and verify that your sound settings are correct:
Inputs : None
Outputs : Headphones (Or External Mixer as appropriate for your setup.)
Sound card : ASIO (Choose Numark USB in the drop-down list.)
Click APPLY.
NOTE: Home FREE does not support using multi-channel sound cards such as Numark DJIO or external mixer use except for the first 10 minutes as a trial of the full VirtualDJ Pro: http://www.virtualdj.com/products/comparison.html
NOTE: Home FREE is for non-commercial use only. It cannot be used for DJ gigs where you are being paid.
Also, make sure that you have the latest DJIO drivers installed from http://www.virtualdj.com/wiki/Common_Device_Drivers.html
Inputs : None
Click APPLY.
geposted Tue 22 Mar 11 @ 11:37 am
I AM HAVING TH SAME PROBLEM
DENON HC 4500
DENON MIXER
DELL INTEL I7 8G HARD DRIVE WINDOWS 7
DENON HC 4500
DENON MIXER
geposted Mon 24 Oct 11 @ 9:09 pm
Make sure that you have the latest firmware and drivers installed from http://www.denondj.com
Then verify that your settings are correct: http://www.virtualdj.com/wiki/DN-HC4500.html
NOTE: If you have configured the software to use the HC4500's sound card and start it without the HC4500 connected, then obviously you will get an error. Make sure that the HC4500 is connected BEFORE starting the software, or change your sound settings to your computer's internal card if you are using your computer without the HC4500 connected (Mouse/keyboard only.)
geposted Tue 25 Oct 11 @ 5:09 am
VirtualDJ works perfectly for the vast majority of users.
Forums like these can sometimes give the false impression that 'everyone' has problems. This is only because users who have problems will actually post in order to seek advice to fix their problem. Users who do not have any problems will in most cases never visit the forums nor wish to participate in them.
ASIO error means that your sound card is not configured correctly or there is a problem with the drivers - Please see http://www.virtualdj.com/wiki/Error%20in%20ASIO%20or%20WDM%20Sound%20Driver.html and http://www.virtualdj.com/wiki/Controller%20Configuration%20And%20Troubleshooting.html
geposted Wed 09 Nov 11 @ 11:13 am
