Forum: Music discussion
Topic: Help: Removing words from song.
Is there anyway to remove all the words from a song and just have the music?
geposted Tue 22 Jul 08 @ 6:37 pm
are you talking about taking off the voice of singer?
yeah thats exactly what im talking about! sorry
Buy the instrumental versions of the song you want.
You could try this software. http://www.make-your-own-karaoke.com/?gclid=CIP89PKe2pQCFQJtFQodfjARkw
It says it removes vocals from tracks for karaoke. Even if you're looking for instrumentals, it should serve the same purpose. I've never used it, so I can't say how well it works. Online record pools are good sources for getting instrumentals, too.
