like the title says. in the effects tab all i get is a grey box when i select the Vokoder plug-in and that's it. won't select in drop down menu either. bummer
geposted Sun 27 Jul 08 @ 3:30 pm
If you are talking about Vokoder of TexZK it works good in my pc
geposted Sun 27 Jul 08 @ 8:00 pm
Try by installing the Microsoft Visual Studio 2008 runtime package. I can't see any other reason to make it not working... I've enabled SSE2 optimisations, but those extensions are supported by any x86 CPU nowadays... (I own an old AMD Athlon X2 4200+).
@ DjTryste: Why do you own it? I've updated it and no licensed users already got it, or try to? Damn... the Net is evolving really fast :D
geposted Mon 28 Jul 08 @ 7:32 am
Yes, with this update, to vocoder work
geposted Sat 02 Aug 08 @ 12:21 pm
ok ,who ever posted the link for the fix, thanks..
geposted Sun 10 Aug 08 @ 12:27 am
