Beat matching is most often off by a fraction resulting in having to constantly push the - or + of the pitch bend throughout the mix. For instance track A is 123.14 pushing sync on track B (originally at 125.00) makes it 123.15. The record feature make the application crash.
I kept using 5.0LE. Now virtual dj 5.2 Pro came out, and I downloaded the software full of hope. its worse now . One of the problems is with the mapping of the hardware software. none of the \"programable keys\" 1,2,3,4,5,6 on the console do what they are supposed to do. Please help
Thanks
Luc Benech
by the way the mac version is OSX 10.5
Thanks
Luc Benech
geposted Tue 29 Jul 08 @ 5:53 pm
same need here. need to map those key's !
geposted Tue 29 Jul 08 @ 10:01 pm
Same problem is present in PC version :(
http://www.virtualdj.com/forums/93792/General_Discussion/Sorry_Team__first_major_moan_of_5_2_(pitch_bend)_with_Hercules_RMX.html
geposted Wed 30 Jul 08 @ 8:34 am
Wonder if this has been updated or addressed- seems like there no response from manufacturer..
geposted Sat 06 Sep 08 @ 2:32 pm
It has been fixed in the last 5.2.1 version
geposted Sun 07 Sep 08 @ 11:52 am
