Forum: VirtualDJ Skins
Topic: Pioneer CDJ700S by RE 1024x768 v2.00 bad download...
Guys,
Has anyone noticed that when you try to dl this skin only one file comes through and it is not in a zip directory? Bad download maybe?
Killabee44
geposted Thu 13 Jan 05 @ 5:27 am
Hi,
Maybe it's your Internet navigator, do you use IE6 ?
If not, change the extension of the file for: .zip
Coyote
geposted Thu 13 Jan 05 @ 6:24 am
Thanks Coyote... You were right. I just had to change the extension. Let me ask you a quick question while Im here...
I downloaded this skin and in the skins dl page fruit said:
"PANNELS! You'll find a "very crossfade" panne and a "Pros with mixer" one."
Now, where can I get the version without a crossfader? There was only one version in the .zip file. Thanks.
Killabee44
geposted Fri 14 Jan 05 @ 5:11 am
SpockiePRO InfinityMember since 2004
Load the normal skin and press the small "3" button above the word "mode" in the middle of the screen.. voila, crossfader gone..
geposted Fri 14 Jan 05 @ 9:08 am
Got it. Thanks.
geposted Sat 15 Jan 05 @ 10:22 am
