Forum: VirtualDJ Skins
Topic: Multi Functions 3 now released !!!
Helllo!
Release 3 of my skin is now OUT!
=> http://www.virtualdj.com/addons/2448/Multi_Functions_3.html
Here is the complete features list:
This skin use the "Internal Mixer" and "FullVideo" skins...
You can resize this skin for your screen with the Sjin Resizing Tool availaible in the "external tool" section of this website.
  • *****V3.0*****
    [list]
  • -AUTO and MIX buttons adapted to VDJ 5.x engine (AUTO to enable automix and MIX to force automix)
  • -Key slider added near to PITCH slider
  • -CUE names can be modified from the skin by clicking on the CUE number on the CUE pannel added in version 1.3
  • -Visuals bugs in Single Deck mode fixed
  • -Track loading bug on the Hidden Deck Watcher is now fixed
  • V2.1
    • -Visuals bugs fixed
    • -Linked audio-video crossfaders option can now be enabled directly from the skin
  • *****V2.0*****
    • -Brand new mode SINGLE DECK! The selected deck use the all screen for total control!
    • -AUTOMIX button adapted for VDJ 5. Clic on "AUTO" to activate the automix and on"MIX" to start "mix now".
    • -"RECORD" function added! Clic on the "RECORD" button to start recording directly from the skin!
    • -New visual based on the "GRID" source.
    • -For coding reasons , the "CPU SAVER" function as been deleted. Use the "NO SCROLLING" mode to decrease your CPU use.
  • V1.5
    • -Function "CLONE DESK" for beat juggle added!
    • -Master volume on the mixer
    • -Display the use of the CPU in percentages too
    • -Brand new function "CPU SAVER" To decrease radically the use of the CPU when yo need it! (by desactivate some visuals which use a lot of CPU - Scrolling, Songpos, Rotation...) Click on the green button (next to the CPU's status bar) to active it!
  • V1.4
    • -Crossfader's curves "NO CROSSFADER" and "USER DEFINED" added
    • -EQ faders are now biggers
    • -Pitch reset button are now biggers
    • -The sample selection from the deck 2's list bug si now fixed!
    • -Visuals bugs when using Timecodes or Cues are now fixed
  • V1.3
    • -6 CUEs added for each deck
    • -Equalizer's faders added
    • -REVERSE function added
  • V1.2
    • -UNLOAD function added.
    • -Crossfader curve can be selected directly from the skin!
    • -some visuals added.
  • V1.1
    • -Scrolling can be disabled for professional use.
    • -Video output can be activate/unactivate from the skin!
  • *****V1.0*****
    • -Mixer and video pannels on the same skin!
    • -Full title, author, bpm, pitch, elapsed time, remaining time.
    • -SYNC and MAGIC BEATMATCH on the same skin!
    • -Brand new fonction LOCK. You can disable the software control by mouse (for private parties when everybody can enter the Dj's area;p. To take the control back, just click on my e-mail adress)
    [/list]
    Don't forget than you can resize this skin with JeremK's resizing tool availaible HERE
    Please tell me if you like it and if you use it...
    SQ;p
    geposted Fri 22 Aug 08 @ 1:21 pm
    How do i see the key number`s???key
    slider is nice
    geposted Sat 23 Aug 08 @ 5:15 am
    titus86Home userMember since 2008
    this is amazing
    geposted Tue 26 Aug 08 @ 4:13 pm
    Link dead can't download.
    geposted Tue 02 Sep 08 @ 9:10 am
    ciocePRO InfinityMember since 2004
    geposted Tue 02 Sep 08 @ 9:12 am
    How do i see the acctual key number`s???key like (a) (b) (C)
    geposted Sun 07 Sep 08 @ 7:40 am
