Forum: VirtualDJ Skins
Topic: removing skins?
Hi,
How would i remove a skin from the list in VDJ or Cue after ive installed it?
I cheked in the skin directory of CUE, but the ones i downloaded are not there, just the default ones.
Sane for the effects.
Thanks.
geposted Wed 27 Aug 08 @ 10:43 am
cstollPRO InfinityMember since 2004
You go to MyDocuments -> VirtualDJ or CUE folder -> Skins folder -- delete the corresponding skin's zip file.
geposted Wed 27 Aug 08 @ 10:45 am
cool thanks man.
this site is great. lot of help.
geposted Wed 27 Aug 08 @ 10:48 am
