Hi,
i have a problem with my virtualdj.. When i play a song in deck 1 and deck 2 and move the crossfader to the middle, i can't hear booth of the decks, i can only hear deck 2. But if i move the crossfader ALL THE WAY over to deck 1 i get sound.. I don't get that "fade effect", What do i do, or whats the problem?
I hope you understood, cause it isn't so easy to explain.
Thanks
DjFreshh
Thanks
DjFreshh
geposted Sun 31 Aug 08 @ 4:55 am
Check in the config-->options tab. The cross fader may be set to cut, which means you only ever hear one deck or the other, never both. Set it to full or smooth.
Denzel
Denzel
geposted Sun 31 Aug 08 @ 6:12 am
Thanks ;)
It worked
It worked
geposted Sun 31 Aug 08 @ 7:27 am
