While in the middle of playing with the software at home it unexpectaly shut down. Music stopped playing and the program closed. I was running it with the hc 4500 while using the internal sound card on the laptop. All files on external drive using firewire 800.
2.6 core 2 duo MBP with 4 gigs of ram
Process: cue [138]
Path: /Applications/cue.app/Contents/MacOS/cue
Identifier: com.atomixproductions.cue
Version: ??? (5.2)
Code Type: X86 (Native)
Parent Process: launchd [83]
Date/Time: 2008-09-01 12:49:07.597 -0400
OS Version: Mac OS X 10.5.4 (9E17)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0
Thread 0 Crashed:
0 com.atomixproductions.cue 0x00069094 non-virtual thunk to CListView::Thread() + 23826
1 com.atomixproductions.cue 0x0000b764 0x1000 + 42852
2 com.atomixproductions.cue 0x0000dfde 0x1000 + 53214
3 com.atomixproductions.cue 0x000cb759 readatomhdr(void*, TQTAtom*) + 156901
4 com.atomixproductions.cue 0x000c9dbb readatomhdr(void*, TQTAtom*) + 150343
5 com.atomixproductions.cue 0x00033a30 non-virtual thunk to IControllerHID::Thread() + 1388
6 com.atomixproductions.cue 0x0006423c non-virtual thunk to CListView::Thread() + 3770
7 com.atomixproductions.cue 0x000b5a78 readatomhdr(void*, TQTAtom*) + 67588
8 com.apple.HIToolbox 0x94280763 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
9 com.apple.HIToolbox 0x9427fb9d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
10 com.apple.HIToolbox 0x9427fa02 SendEventToEventTargetWithOptions + 58
11 com.apple.HIToolbox 0x942ae83c ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 356
12 com.apple.HIToolbox 0x94280b1c DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2134
13 com.apple.HIToolbox 0x9427fb9d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
14 com.apple.HIToolbox 0x9429c4ee SendEventToEventTarget + 52
15 com.apple.HIToolbox 0x94309504 ToolboxEventDispatcher + 86
16 com.apple.HIToolbox 0x94305d5e RunApplicationEventLoop + 222
17 com.atomixproductions.cue 0x000b54ec readatomhdr(void*, TQTAtom*) + 66168
18 com.atomixproductions.cue 0x00002cf2 0x1000 + 7410
19 com.atomixproductions.cue 0x00002c19 0x1000 + 7193
Thread 1:
0 libSystem.B.dylib 0x92e77506 semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x92ea984f _pthread_cond_wait + 1244
2 libSystem.B.dylib 0x92eab0d3 pthread_cond_timedwait_relative_np + 47
3 ...ple.CoreServices.CarbonCore 0x945ab2fe TSWaitOnConditionTimedRelative + 246
4 ...ple.CoreServices.CarbonCore 0x945ab0de TSWaitOnSemaphoreCommon + 422
5 ...ickTimeComponents.component 0x90161dee ReadSchedulerThreadEntryPoint + 4724
6 libSystem.B.dylib 0x92ea86f5 _pthread_start + 321
7 libSystem.B.dylib 0x92ea85b2 thread_start + 34
Thread 2:
4 ...ple.CoreServices.CarbonCore 0x94635a3f MPWaitForEvent + 197
5 com.atomixproductions.cue 0x000a5707 readatomhdr(void*, TQTAtom*) + 1171
6 com.atomixproductions.cue 0x000a5751 readatomhdr(void*, TQTAtom*) + 1245
7 ...ple.CoreServices.CarbonCore 0x945ca55b PrivateMPEntryPoint + 56
8 libSystem.B.dylib 0x92ea86f5 _pthread_start + 321
9 libSystem.B.dylib 0x92ea85b2 thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x92e774a6 mach_msg_trap + 10
1 libSystem.B.dylib 0x92e7ec9c mach_msg + 72
2 com.apple.CoreFoundation 0x94f4d0ce CFRunLoopRunSpecific + 1790
3 com.apple.CoreFoundation 0x94f4dcf8 CFRunLoopRunInMode + 88
4 com.apple.audio.CoreAudio 0x95e64468 HALRunLoop::OwnThread(void*) + 160
5 com.apple.audio.CoreAudio 0x95e64304 CAPThread::Entry(CAPThread*) + 96
Thread 4:
3 com.apple.audio.CoreAudio 0x95e73a4b CAGuard::WaitFor(unsigned long long) + 213
4 com.apple.audio.CoreAudio 0x95e75606 CAGuard::WaitUntil(unsigned long long) + 70
5 com.apple.audio.CoreAudio 0x95e73dab HP_IOThread::WorkLoop() + 759
6 com.apple.audio.CoreAudio 0x95e73aaf HP_IOThread::ThreadEntry(HP_IOThread*) + 17
7 com.apple.audio.CoreAudio 0x95e64304 CAPThread::Entry(CAPThread*) + 96
Thread 5:
Thread 6:
3 com.apple.Foundation 0x93414e8c -[NSCondition waitUntilDate:] + 236
4 com.apple.Foundation 0x93414ca0 -[NSConditionLock lockWhenCondition:beforeDate:] + 144
5 com.apple.Foundation 0x93414c05 -[NSConditionLock lockWhenCondition:] + 69
6 com.apple.AppKit 0x951a6470 -[NSUIHeartBeat _heartBeatThread:] + 753
7 com.apple.Foundation 0x933cef1d -[NSThread main] + 45
8 com.apple.Foundation 0x933ceac4 __NSThread__main__ + 308
9 libSystem.B.dylib 0x92ea86f5 _pthread_start + 321
10 libSystem.B.dylib 0x92ea85b2 thread_start + 34
Thread 7:
2 com.apple.audio.midi.CoreMIDI 0x00859f3f XServerMachPort::ReceiveMessage(int&, void*, int&) + 101
3 com.apple.audio.midi.CoreMIDI 0x0084c4cf MIDIInPortThread::Run() + 111
4 com.apple.audio.midi.CoreMIDI 0x008500d5 XThread::RunHelper(void*) + 17
5 com.apple.audio.midi.CoreMIDI 0x0085aa1e CAPThread::Entry(CAPThread*) + 96
Thread 8:
0 libSystem.B.dylib 0x92e7e68e __semwait_signal + 10
1 libSystem.B.dylib 0x92ea936d pthread_cond_wait$UNIX2003 + 73
2 com.apple.audio.midi.CoreMIDI 0x0085a3d9 CAGuard::Wait() + 93
3 com.apple.audio.midi.CoreMIDI 0x008502ef Task::Run() + 143
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x006cb168 ebx: 0x00000000 ecx: 0x00000000 edx: 0x006cb0e0
edi: 0x00000000 esi: 0x00000000 ebp: 0xbfffe8f8 esp: 0xbfffe8e0
ss: 0x0000001f efl: 0x00010282 eip: 0x00069094 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000000
AND
9/1/08 12:30:40 PM cue[138] Warning once: This application, or a library it uses, is using NSQuickDrawView, which has been deprecated. Apps should cease use of QuickDraw and move to Quartz.
9/1/08 12:49:12 PM com.apple.launchd[83] ([0x0-0x16016].com.atomixproductions.cue[138]) Exited abnormally: Bus error
Not sure if this is what u need. Please forgive me if it is not and instruct on where to look
Process: cue [138]
Version: ??? (5.2)
Report Version: 6
Crashed Thread: 0
Thread 0 Crashed:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
cr2: 0x00000000
AND
geposted Mon 01 Sep 08 @ 12:10 pm
Thanks for the crash report.
I'm sure it will be looked into;)
geposted Mon 01 Sep 08 @ 12:38 pm
Any update on this ?
At least confirmation that it is being looked over .
geposted Tue 02 Sep 08 @ 3:38 pm
this makes me feel great about doing gigs this weekend. i miss 5.07
geposted Tue 02 Sep 08 @ 4:32 pm
My sentiments exactly. I'm dying to use my mac live but i am scared $hitless . Picture it crapping out during the first dance ;0 (
Immediate loss in court, full refund and bad rep.
I can't afford any of those .
geposted Tue 02 Sep 08 @ 4:57 pm
Can someone please, at the very least acknowledge that this is being looked at .
geposted Wed 03 Sep 08 @ 4:10 pm
This happened early to me on last saturday night! Don't know why but it sucked, luckily it was just the beginning of the party!
Ran it for hours after with no problems?
DJ Matt
DJ Matt
geposted Wed 03 Sep 08 @ 10:36 pm
I hope it's like a one time thing and never happens again. I have a huge wedding this saturday but i think i'm going to hold off on using my mac until someone from the staff tells me something, anything at this point.
I am not liking the way i am being ignored.
geposted Thu 04 Sep 08 @ 3:45 pm
DJ Phenominal... I hope you get your issues fixed. I'd help, but I don't really have answers for your problems. Did you try sending a ticket to VDJ support? I see that you have a couple crash reports in the forum. Could be worth a try to contact them directly. Good luck.
geposted Fri 05 Sep 08 @ 1:21 am
Bump
geposted Mon 08 Sep 08 @ 3:38 pm
Bump again !
geposted Wed 10 Sep 08 @ 4:45 pm
This isgetting worse and worse, its to the point where staff does not even respond to a post?
geposted Wed 10 Sep 08 @ 4:51 pm
Hi djphenominal, have patience as already indicated by DJ Cel in the other thread that this will be investigate. So if they have the solution they will reply to it.
@automag68, be informed that teamers and the dev staff usually look ard in the forum and this are not forgotten.
Regards;)
Mac Technical Support Forum Moderator.
Regards;)
geposted Wed 10 Sep 08 @ 4:59 pm
