Trying to get the timecoded vinyl to work, I followed the guidelines from the online manual at
http://www.virtualdj.com/products/timecode/
But never the less the timecode quality stays at 0% in the timecode config screen.
And when pitch on the turntable = 0
pitch in VDJ deck shows -4.8%
I am using a MAYA44 USB, have the ground from my turntable wired to the chassis of my PC....
BTW I am using the SYNQ timecoded vinyl, should be compatible with VDJ, since the VDJ timecodes are still not on store..... was forced to do something.
Any clues?
Thx.
Any clues?
Thx.
geposted Wed 19 Jan 05 @ 10:59 pm
Obviously, these time coded vinyl's just aren't compatible. ;) You can compare with VDJ's timecode here:
http://www.virtualdj.com/products/timecode/VDJTimeCode.mp3
geposted Thu 20 Jan 05 @ 12:01 am
My mixvibes vinyls also give 0% and via versa.
They are just different timecodes.
It's normal.
It's normal.
geposted Thu 20 Jan 05 @ 2:33 am
Oh sh...., They fooled me.
Well it was worth a try, pitty of the money.
But can't VDJ make it possible to work with several TCV?
It see that some other digital DJ apps are quiet capable of doing this.
Would be nice, and would attract some people to VDJ, whom are now using other apps...
geposted Thu 20 Jan 05 @ 9:24 am
Also the pitch on vdj is different to the pitch on your turntable so it wont read the same anyway
geposted Thu 20 Jan 05 @ 5:47 pm
The same thing happens to me when ime using VDJ timecoded vinyls. I am using a m-audio Asio interface and when i switch to the timecoded vinyl the song drops in bpm by about 10 bpm, and i cant seem to figure out what is causeing this problem. I also cannot get the vinyls to change to 100% it just fluctuates from like 0 to 13 to 56 to 0 and on and on to diffrent numbers. It never stays stagnant or reaches 100. Could somebody please tell me what is going on, could the absence of grounding wires cause this problem, i dont see how they could but.....?
geposted Mon 21 Mar 05 @ 8:20 pm
@neptunekiev ...what version are you using?
geposted Mon 21 Mar 05 @ 9:05 pm
ime using my friends computer currently with my tables cause i lack a computer fast enough to run the program, ime not at his house, but i beleive he has 2.02.
geposted Tue 22 Mar 05 @ 12:23 am
2.02 with TCV?
geposted Tue 22 Mar 05 @ 1:38 pm
The TCV work with VDJ since 2.01 but for better result, we recommand to use it with the last version 2.06
Coyote
Coyote
geposted Tue 22 Mar 05 @ 4:36 pm
