I have a GEMINI CDM-500 and I was thinking of purchasing Virtual DJ for it but I want to know if it will work with my decks first. I have a M-AUDIO Delta 66 ASIO compatible sound card. Any ideas if it will work with my setup?
Here is a link to my CDM's
http://www.geminidj.com/cdm500.html
And my sound card
http://www.m-audio.com/products/en_us/Delta66.html
Thanks for the help guys.
And my sound card
geposted Tue 09 Sep 08 @ 10:14 pm
Yeah, that should work in a timecode set up
geposted Wed 10 Sep 08 @ 2:36 am
Even if the outputs on it are only 1 RCA output for Master and 1 RCA output for Record? I also have 1 RCA input (Input 1) and another (Input 2). I can take a picture if needed. I'm just having trouble picturing how VDJ will recognize which side of the deck is which. Are there two different timecodes for each timecoded cd? Thanks again for the help.
geposted Thu 11 Sep 08 @ 12:56 pm
well, I don't know then. All I know, is that you need 2 inputs per "deck" to go into your soundcard.
Sorry about that.
Sorry about that.
geposted Thu 11 Sep 08 @ 1:02 pm
