Well i just downloaded virtual dj v2.05 trial version from this website and im having a problem i downloaded i install it and i click on the shortcut on the virtual dj icon and an error comes up and says "database is corrupted and when i click ok another error comes up and says " invalid skin file(error line%i in the xml). can some1 help me out and tell me how im supposed to install it right because i know the file is not corrupted because i downloaded it from this website. by the way this virtual dj v2.05. any suggestions, i reinstall it like 20 times and i keep getting this error alot.
geposted Tue 25 Jan 05 @ 5:39 am
please uninstall, and DELETE the Virtual DJ folder.
The xml error is because of a bad skin, and the database error might only be because you restart the program to fast (virtualdj need to rebuild the database each time it quits)
geposted Tue 25 Jan 05 @ 12:26 pm
so u want me uninstall virtual dj then delete the virtual dj folder and then try to install it and it should work right. after i install it do i click on the virtual dj shortcut on the desktop right away. let me try
geposted Tue 25 Jan 05 @ 10:01 pm
did it help? :) hope so
geposted Fri 28 Jan 05 @ 4:29 pm
