I briefly looked over some features to see if an autoplay feature exists, but did not find it. Is there a feature on the Limited version of VDJ that will let me play a whole cd from 1 to 10 for example without a stop?
Thanks in advance.
ps, dont stone me, im sorry if its an obvious place and im just too blind to see it.
Thanks in advance.
geposted Thu 02 Oct 08 @ 12:39 pm
im not at home, but through a little bit of looking around the forum, the autoplay option should be on the playlist side and can be activated for continues play?
geposted Thu 02 Oct 08 @ 1:48 pm
sure is, we call it automix, after lining up your tunes and one already in a player left click on the circle above the plus sign and it will turn green, you are now in automix, press play on your deck and it will play continuous in that player leaving the other one free, to skip to another tune simply double click on it.
geposted Thu 02 Oct 08 @ 4:08 pm
Actually, you don't need to load a song in a deck before pressing the automix button. Just add your songs to the playlist area on the right and click the automix button and the 1st song will automatically load.
geposted Thu 02 Oct 08 @ 4:28 pm
got it, thank you.
geposted Thu 02 Oct 08 @ 7:47 pm
no probs...
geposted Thu 02 Oct 08 @ 7:50 pm
This problem just started last week. I use version 4.2r1 and have problems with auto play. All else works great. When I set up a play list for when I need a rest room break or to visit someone in the crowd (bar break) this crazy problem arises. One song will be playing, next song awaiting on next deck, when song one finishes and the next deck will auto mix. Up to now no problem. The next song on the play list will load onto the first deck and sometimes after that song loads - the number 2 song in the play list will reload onto deck one and the song that is now playing will skip several seconds to minutes into it. Can someone please let me know if I changed some setting by accident. I did add Norton 360 to my laptop last week and that may have done something. I don't use this as dedicated system yet. This problem is not constant but seems to happen to the same songs when it does. This sounds confusing so please let me know if you need any more info. Thanks
geposted Mon 13 Oct 08 @ 7:21 am
enter the serial that you got when you purchased the program, then you can download the newest version that works as it should.
also, if you have downloaded the program from another site (cracked and illegal version), you might have gotten a bunch of viruses that is screwing up your machine.
-Ron
geposted Mon 13 Oct 08 @ 7:38 am
