Forum: Old versions
Topic: DAC 3 mapper with VDJ 5.2?
djburnzPRO InfinityMember since 2006
Hey guys, I want to upgrade from version 4 to the new 5.2 VDJ, but looking at the tools download section, its showning that the custom DAC-3 mapper is only up to version 4. Is there an update, or does the custom dac3 mapper from 4 have the same functionality for version 5?
If I can use the version 4 mapper, how would I install it into version 5? Thanks everyone.
geposted Fri 10 Oct 08 @ 7:17 pm
It still works, you install it in exactly the same way :)
geposted Fri 10 Oct 08 @ 8:48 pm
To install it, you will need to copy dac3.dll to My Documents\VirtualDJ\Plugins\ControlDevice
geposted Sat 11 Oct 08 @ 12:43 pm
