Forum: Old versions
Topic: VESTAX VCI-300 owners be careful!
All Vestax VCI-300 users,
It has been discovered that the controls of some VCI-300 units may possibly freeze(disable) during operation with ITCH under several circumstances. If you are a owner of a Vestax VCI-300 and have experienced this error, please contact your local Vestax distributor for assistance.(The errror can be checked by rotating the right (Bch) jog wheel when in use with ITCH). We apologize for any inconvenience this may have caused you.
Vestax Corporation
-Object product / Serial number-
DJ Controller VCI-300
- 85 F (K) 01 ****
- 86 F (K) 02 ****
- 87 F (K) 03 ****
- G87 01 ****
- G87 02 ****
- G88 03 ****
-Error content-
The controls of the VCI-300 freezes(is disabled) during operation with ITCH when the right JOG wheel is operated.
http://www.vestax.com/v/info/newsevent/detail.php?id=81
geposted Sat 18 Oct 08 @ 2:38 am
hi!!! i have dj console vestax vci 300 end i want to dowload software. how i kan do it???
You can start by not hijacking someone else's thread ;)
You need to click on "Modify my profile" and enter your serial number in the licenses section.
I NOW THAT THANKS!! . I PUT E SERIAL NUMBER THAT THERE IS AT VESTAX CONSOLE, I CLICK REGISTER BUT AT SCREEN APPEARS THAT ----> ...This serial is not valid...
SERIAL NUMBER IS BACK OF CONSOLE???
where is this code ( keycode )??
I have to buy unnatural virtual dj??
Do you own VirtualDJ ? Did you buy it ? Where did you get it from?
As above - the VCI-300 doesn't come with VDJ so you must have purchased it from somewhere. If you purchased the Atomix version, then you will have the serial number in a conformation email. If you purchased the Numark version (Cue) then the serial number will be included with that.
This update is for those who bought the VCI 300 back in 2008. If you bought yours brand new from the store in 2009, you are fine.
If you want to download software, you have to go to the serato website and look for the Itch download. http://www.serato.com/downloads
can i work virtual dj with VESTAX VCI-300 ;
If you upgrade to Pro then yes.
Just as an aside.....
Vestax equipment not supported in the serial add in list then? I bought one recently after looking around in China and it was the best available as far I could see. Not all that bothered tbh but it would be nice to add it to my profile ¦:-P
Loving the VCI-300 MKII btw - just wish I'd read the post about it back in '09.... perhaps I wouldn't have bothered lol
Flame ON!
Hello, I need help with making virtual DJ work with my VESTAX VCI-300. It works perfectly with Serato but I want to work with virtualDJ so the note that it gives me is : "Error in the ASIO driver not enough channels" and it follows with another one "Error in the ASIO sound driver: Your soundcard is probably not connected, or the settings are incorrect. If anyone has an idea how I can fix this please help :) The thing that happens is virtualDJ starts but it's just not connected with the VESTAX.
Open your config settings
Open "Advanced Set Up"
Set your Main output to what ever you're running sound thru. If you have N external soundcard for headphone cue, it has to also be selected under "headphones". It should be the name of your external card
You're replying to a two year old post...
[closed]
