i know that VDJ has the buttons where you can select a portion of a song to loop (1/2, 1/4, 1/8, etc)
but, am i missing an easy way to make an whole song loop seamlessly?
like, if i wanted to load an mp3 that's simply a beat loop, and make the whole track repeat without using the buttons mentioned above...is it there? am i just overlooking it?
i tried downloading a plugin for looping, but it didnt loop seamlessly. there was a brief hesitation when the loop repeated.
suggestions?
suggestions?
geposted Sun 30 Jan 05 @ 6:30 am
Just create a loop as you would normally by setting a cue point at the first beat that you want to start the loop from. Go to that cue point and select the loop lenght. Set the loop to the max lenght which is 128 beats. If your bpm is correct the loop should be seamless.
Killabee44
Killabee44
geposted Sun 30 Jan 05 @ 4:34 pm
