Hello,
I am hoping to get some help on the forum as my technical support ticket has gone unanswered.
I bought virtual vinyl and can't perform a time code config. I have been trying for a for a while now. I have even tried to bypass the mixer and get a time code config with the virtual vinyl mixer only interface.
My computer setup is:
2.4 gig dual core proc.
4 gigs ram
80 Gig Hard rive for the operating system and a 1 terabyte hard drive for content
windows XP
I have the virtual vinyl kit with the time code lp's and the usb hardware to connect my mixer and turntables.
I checked the wiring about 100 times and it is correct.
My sound equipment is as follows:
Behringer DDM4000 mixer
2 - Gemini TT-02 turntables
Everything works when I use records in an analog environment (bypassing the virtual vinyl software).
The error I get when trying to do a time code is (no time code signal found check wiring and volume on sound card)
The two dots showing time code quality are red and show 0%. My sound card is working and I have volume on all other programs. I am using the virtual vinyl sound card and 3 Chanel mixer in the set up.
So where do I go from here? Is there a phone support number? I would rather get this working than return it. Thank you for any assistance.
After I wrote the above I found:
I have been messing around with it more and notice that the software responds to my turn tables. I can see the virtual turntables turning when I have the time code record on and it and the virtual turntable stops and goes backward if I manipulate the real one. It still won't let me time code though.
Much appreciation for anyone who can help me with this. At almost $ 400.00 I do not want to use the virtual vinyl kit as a paper weight.
4 gigs ram
windows XP
geposted Wed 22 Oct 08 @ 4:08 pm
jryan1111's post below actually fixed my issue. I can't believe that you have to be so strict with the order you turn on your equipment but I guess that is that.
The solution to my problem is here:
http://www.virtualdj.com/forums/98289/PC_Version_Technical_Support/Timecode_Issue.html
In case anyone else has time code issues.
Thanks jryan111
geposted Wed 22 Oct 08 @ 4:47 pm
