Forum: Old versions
Topic: m4p files(itunes) not loading showing error
Hello all,
My new system is running really well and I am really happy about that.
Just a few adjustments, this one is that my purchased songs from Itunes that were transferred via dvd s from my Mac
to my ultra cool and very affordable PC is showing errors when loading into VDJ.
I have authorized the purchased songs from itunes to the new computer. However still not loading.
My guess is that there is something in the settings in Codec that I need to add, do?
Thanks!
Junito
geposted Fri 24 Oct 08 @ 9:04 am
Unfortunately, Apple DRM protected music can only be played in iTunes and on iPods.
Only unprotected (And more expensive) iTunes Plus music can be played in VirtualDJ and other applications.
wow!
I had no idea that might be the case.
Thank you.
Junito
Junito, Have you tried burning the songs onto a CD from itunes in an mp3 format and then ripping the songs from that CD or your PC? I do it all the time without any drm issue. I think you mentioned in your post you burned the songs on a DVD. That could be an issue.
Bob
ZOWIE!
Bob that worked!
What i did was create a new playlist, placed the purchased songs in the new list, burned from that list as an audio cd and wallah, I can add to itunes without any issues, thus being able to "ROCK DA HOUSE" in VDJ!
yeah baby!
Thanks BOB!!!!
Junito
