Hello All I have a strange problem
I have always regularly updated my version of VDJ and was currently running VDJ version v5.2.1 on a Vista Home Premium Laptop below are my specs
Dell XPS M1530
Duo Core T8300 2.4 GHz
4Gb RAM
NVIDIA Geforce
8600 M GT video Card
ExpressCard Sound Blaster X-Fi Xtreme Audio Notebook
I have no extra software and use the Laptop exclusivly for VDJ
When I use any version of VDJ 5.0 or above Audio only seems runs well for a short period of time a minute or so it sounds fuzzy and mettalic if I change just about any setting in the Performances Tab The sound becomes OK again for a short period I tested this bey installing other V5.xx versions I had on some old saved backup (v5.0.rev6) and experienced the same problems. I know Vista handles sound poorly so I was assuming it had to do with Vista I never used to have any problems with my XP machines. The other odd thing is that if I close VDJ during the "poor sound" issue and fire up WMP the sound is good. Now to add to this confusion I was able to do a gig for 4 hours with not much hassle after I shut down and started up the next day with NO system changes the problem occured this was after a clean windows install. I have tried a 3 reformat and install , shutting down processes, adding removing codecs etc. etc.
So on a whim I searched my backup drive for a pre-V5 bersion of VDJ and found v4[1].3 installed it and so far not even a glitch in the sound there is an odd thing going n with the text dissaperaing on the configuration menu buttons in the effects menus but its better than fuzzy mettalic distorted sound
I thought I was al good
UPDATE: IT DID THE SAME THING!! ON VERSION v4[1].3 (
My questions are
What did V5 change in the way it handles sound?
Is this a Latency Issue?
Is this problem limited to X-Fi, Vista
If it is a performance issue what settings can I use in V5 in the performance tab to get rid of the problem
Any other setting suggestions?
If I am stuck using V4.xx
am I missing fonts for the menus, which ones, and where do I get em and which V4 was the latest and most stable?
Thank You Thank You
Clay
Dell XPS M1530
4Gb RAM
NVIDIA Geforce
My questions are
Thank You Thank You
Clay
geposted Sun 02 Nov 08 @ 1:28 am
Well mabey I spoke too soon the same thing seems to occur in both 5 and 4 versions of VDJ
To recap:
Upon start up VDJ performs wel.l after a random amount of time about 1-5 minutes the audio becomes distorted/fuzzy mettalic
If I change ANY setting in the performance Tab it goes away monentarily the returns...This problem does not occur in any other windows based programs including a copy of Traktor LE that came with My Numark Total Control
To recap:
geposted Sun 02 Nov 08 @ 5:27 pm
POSTED FROM THE FOLLOWING THREAD
http://www.virtualdj.com/forums/98616/PC_Version_Technical_Support/Dell_Studio_Problems.html
Question is the Dell Studio similar or in the same family as the XPS M1530 ? Is your problem have any resemblance to my recent qustion?
http://www.virtualdj.com/forums/98892/PC_Version_Technical_Support/Version_v5_2_1_X-Fi_Vista_Sound__help_Please.html?search=clay&page=1
I am still looking for answers right now I am trying the following
I have been mixing for 10 minutes now and the Audio is holding up basically I just turned everything waay down or off
One a sidenote I was using CUE Remix by Coive v1.6 although I have never heard of a Skin causing an Audio problem 1440 x900
20 minutes and countin..........
geposted Sun 02 Nov 08 @ 6:22 pm
i have the vista service pack 1( 64 bit)... i tired that and its still doing it on my herclues rmx i tried the m-audio fast track pro and still im getting the poping sounds
geposted Tue 18 Nov 08 @ 9:23 pm
I have a XPS m1330 and Vista x64. See my post about nvidia powermizer causing audio issues:
http://de.virtualdj.com/forums/93533/PC_Version_Technical_Support/)))))))))Snap-_crackle-_pop_(((((((((((.html
This will ix your issue.
-David
-David
geposted Tue 18 Nov 08 @ 9:27 pm
