Anyone else have the problem that songs over 10 min in legnth tend to crash VDJ?
First, songs over 10 min don't load the waveform on VDJ and second whenever I have a crash it is usually when I have an extended mix (10 min or over) on.
VDJ 2.06 Laptop 3 gig, 512k, 60 gig HD, xp pro sp1.
Thanks.
Thanks.
geposted Wed 02 Feb 05 @ 3:54 am
Change max load in the fame settings to always, add another 512 mb of ram.
geposted Wed 02 Feb 05 @ 5:16 am
Hi-
Thx for the tip. I changed max load to always, in my version it is under the general tab V2.06 (config>general tab>max load>always).
We will see in time if that helps.
Off to NYC this weekend & maybe try VDJ in real world environment...
Cheers
Cheers
geposted Thu 03 Feb 05 @ 7:40 am
don't forget the 512mb of ram!
i have very few (if any) songs > 30mn, so I leave mine set to that..
jus seems like the "safe bet" option
geposted Fri 04 Feb 05 @ 12:04 am
Max load to "always" is not a safe option. If you load a big file (a mix for example) virtual dj will use
the swap file and this is not good.
geposted Fri 04 Feb 05 @ 2:32 am
