Hello,
i need the Black 1280x800 v3 in 1024x768. Can anyone help?
geposted Tue 04 Nov 08 @ 5:26 pm
https://virtualdj.com/addons/4369/Vinyl_Scratch_variations.html ;)
Black 1024x768
Black 1024x768 v2
Black 1280x800 v3
Gray 1024x768
Gray 1024x768 v2
Gray 1280x800 v3
Black 1024x768
Black 1024x768 v2
Black 1280x800 v3
Gray 1024x768
Gray 1024x768 v2
Gray 1280x800 v3
geposted Wed 05 Nov 08 @ 1:37 am
Black 1024x768
Black 1024x768 v2
Black 1280x800 v3
Gray 1024x768
Gray 1024x768 v2
Gray 1280x800 v3
Black 1024x768
Black 1024x768 v2
Black 1280x800 v3
Gray 1024x768
Gray 1024x768 v2
Gray 1280x800 v3
Hi,
need the 1280x800 v3 in 1024x768
geposted Wed 05 Nov 08 @ 3:33 am
you can use the Skin Resizer by JeremK but only to create or:
1228x768
1024x640
else the skin will be deformed
1228x768
1024x640
geposted Wed 05 Nov 08 @ 7:35 am
1228x768
1024x640
1228x768
1024x640
with the resizer the skin will be deformed. The author of the skin is a no license user, can anybody else make this skin in 1024x768???????
geposted Wed 05 Nov 08 @ 12:16 pm
I've just performed a resize of the skin to 1024x768 and the result is great!
The only bad graphic glitch is the "CBG monitor" in the center of the skin, just below the waveform.
Here are the exact steps to follow to get the same result as i have:
1. Unzip the Skin package, or unzip only the skin you want to resize.
2. In the tool, click on the "..." Input button to open the XML of the skin that needs resizing.
3. In the Output size box write 1024, and then click on the "x" button. The output height should now be at 640.
4. Tick "Resize XML" and "Resize Picture".
5. Tick "Browser Options" and then the "Browser" button. A message window should appear, this is a bug from the software, but not a big issue. In the font listbox, correct Verdana" to Verdana. And change the font size to 12. (You can leave the font size at 13 but the browser will then show less files at the same time).
6. Click on "Do the job".
Now click on the "Preview Skin" button. If the skin looks good to you (the size of the buttons and so on are good for you), you should consider buying the licensed version to be able to continue on the next steps.
7. Click on the "Licensed" menu, then on "Reload last created skin".
8. In the output size now write 1024 x 768.
9. Select the Output filename by clicking on the "..." output button.
10. Click on "Browser Resize". A message window should appear. This is only to tell you that Browser resize and regular resize cannot be performed at the same time.
11. Untick "Browser Options".
12. Click on "Do the Job".
Now you can preview the finished skin. It looks exactly the same as the 1024x640 skin, only the browser is bigger to fill in the screen.
Now Drag and Drop the finished skin (XML and BMP file) in the original skin package.
And you can finally use the skin.
geposted Wed 05 Nov 08 @ 5:51 pm
Thanx for your work. I can not buying the license, because i have no visa or other credit cards. I need the x 768 and the normal Skin-resizer cannot do this. Can you make the skin for me, please?
geposted Thu 06 Nov 08 @ 3:30 am
Hi,
The resized skin is already made, but i'm sorry i won't send it to you.
It took me alot of time to create the Skin Resizer Tool, therefore it isn't free to use unless you use the "basic resize" option.
You do not need a VISA or credit card with Paypal anymore. If you register you can use your bank account.
geposted Thu 06 Nov 08 @ 2:59 pm
@Diskoschlampre
I suggest you to buy this wonderful and powerful tool!
You will be satisfied about your purchase
geposted Thu 06 Nov 08 @ 8:03 pm
