Does anyone have a working mapping for the Allen & Heath Xone 4D.
Just ordered mine and hoping to use it the weekend I get it. Just to get me started.
Cheers,
Ross
Cheers,
Ross
geposted Thu 27 Nov 08 @ 8:34 pm
Maybe it's similar to XONE 3D brother
http://www.virtualdj.com/addons/4226/Xone_3D_Midi_map_with_Template_Overlay_image.html
geposted Fri 28 Nov 08 @ 1:15 am
looks like one sweet piece of kit - how much did you shell out for it? did the mapping work for you?
geposted Wed 10 Dec 08 @ 9:04 am
RRP is £1800. Look around, I got mine from a friend who is a dealer and saved a bit.
I've got it mapped pretty well but still a couple of features I'm working on/improving.
Sound fantastic on mac, some popping issues on windows which I've not had a lot of time to check as yet. Hopefully VDJ config and not a driver issue.
I am having problems with the VDJ config which is preventing me from using Time Code with it just now.
Otherwise it's fantastic and if I get all these issues sorted out will make my life so much easier.
Ross
Ross
geposted Wed 10 Dec 08 @ 8:22 pm
hi ross
did you manage to get a 4d mapper
fusion
fusion
geposted Mon 03 May 10 @ 2:05 pm
I've written my own definition file and created a mapper.
It's not perfect yet and I keep changing my mind about elements.
But that's the beauty of it, once you have the definition, it's easy to change around.
My only gripe is that VDJ does not have better support for the multi-channel soundcard.
In Traktor it works brilliantly.
Ross
Ross
geposted Sun 16 May 10 @ 8:54 am
