Forum: Old versions
Topic: Play Stutter Button
Thanks for the codec advice, it seems to have solved the problem with the songs not starting on Cue... I played last night, and no matter how hard i tried i could not get it to mis the cue... Very cool!!!
geposted Sun 30 Nov 08 @ 2:09 pm
glad to hear it!
What was the advice ??
I am noticing this too, what codec are u using now?
Is it only happening on mp3 files?
the advice was to change the default mp3 (or whatever format youre having trouble with) codec to the quicktime decoder. I think if you've copied the files from a PC that was formatted NTFS, you might have trouble with the quicktime decoder...at least I did...
J
I have noticed it with mp3 and I am using the default decoder, will try quicktime to see if it makes difference
Yes;)
J
thats what if is? no wonder i had a problem....
but all the songs that i get fresh from my pool should work perfect? that must be it... damn
I am having a issue where when i hold c to cue play any track on any deck that it starts to stutter from that cue point. What do I do to fix this issue. I have already removed software reset computer and still same issue.
Thats the default behavior for the CUE button, and always was like that (play-stutter from the Cue as long as it is pressed). I dont see the "issue" here, and if there is for you, please explain what should be the behavior for you.
