Forum: VirtualDJ Plugins
Topic: can someone please make a proper reverse plugin
djzeroPRO InfinityMember since 2003
can someone please make a proper reverse plugin, i mean one that updates the song pos and when you release the reverse key it continues to play from where you released the button instead of the where the song would have been if you diddn't press reverse.
all i want is a simple plugin like the current reverse (not full reverse, it doesn't work with 2.06 and i dont lke the interface) that does what is stated above.
geposted Wed 09 Feb 05 @ 11:40 am
kaleoPRO InfinityMember since 2003
I will create a Full Reverse V2.
geposted Wed 09 Feb 05 @ 1:00 pm
claxPRO InfinityMember since 2004
Thanks kaleo.
geposted Wed 09 Feb 05 @ 2:44 pm
thanks kaleo, much better now, only one more thing if you've got the time, is is possable to make the songpos wind backwards instead of changing over as it does at the moment its always seemed abit confusing and doesn't account for the loud and soft sections displayed on songpos...
as a result of this it also shows the incorrect position on the waveform display which is the main thing i'd like to be fixed if its possible. if it could just make the waveform to start going backwards like if you change the phase of the TCV signal, it would be awsome
thanks for getting it this far
dj zero
geposted Sun 13 Feb 05 @ 2:36 pm
djcelPRO InfinityModeratorMember since 2004
Thank you very much Kaleo !!! Great work as usual
However I have noticed something strange: when the song reaches the end (with Restart Forward), slot 1 switch on whereas the plugin is in slot 2.
Verify your slots please
geposted Mon 14 Feb 05 @ 1:12 am
@Kaleo
I have the same problem when i put the plugin into slot=3, at the end of the song , in restart forward and normal mode but not with Loop mode, deck 2 switch on or off
please could you correct that, it's very annoying
geposted Mon 04 Apr 05 @ 12:31 am
Right, I'm back from hollidays, I will have a look at this soon.
geposted Mon 04 Apr 05 @ 8:42 am
Is there any way of shooting the video out of virtual DJ so that you can use rear projection? I am so limited on front projection and can not get the video to reverse or mirror itself for rear projection.. Please let me know. You can catch me on facebook at:
http://www.facebook.com/profile.php?id=726402961
geposted Wed 19 Oct 11 @ 2:11 pm
Please start a new post rather than bumping a 6 year old one on a different topic.
Thanks.
geposted Wed 19 Oct 11 @ 2:27 pm
