I was checking and downloading all the skins available.
I don't think any of them works for me 100%.
What skin do you use? and why?
I want my skin to be professional, made for external controller/mixer, SIMPLE, CLEAN, and have the most important features (display cue position on meters and on the waveform, NO crossfaders, EQs, etc.)
Another great feature i saw on a skin was 2 waveforms, one for each deck. That was great.
I think i'll start my own skin soon.
So what skin do you use?
geposted Wed 09 Feb 05 @ 9:46 pm
I don't use only a skin.
As my PC is in my living room I prefer to change sometimes.
I often use: "Floop DJ" 1024*768 and "CDJ700".
I don't have any external controler (except a mixtable) so I prefer to have the turntables in the skin.
I don't really like separate waveforms.
That's my opinion.
Regards,
Clax
That's my opinion.
Regards,
Clax
geposted Thu 10 Feb 05 @ 7:33 am
Same here, there is currently no skin that i like 100%, so i had to learn how to create mine.
Its in "beta" test now... in real work not at home, has a clean interface and other things you ask for
Except the eq (wich will not hurt you the way it is) maybe its what you need.
Take a look at:
https://virtualdj.com/forum/display.html?topic=10077
and i think you are Greek so take a look here:
https://virtualdj.com/forum/display.html?topic=10078
Take a look at:
geposted Thu 10 Feb 05 @ 10:13 am
A professional dj use program with external controller. This is what i think!! I'm employ a dac2 and .
I'd like see more skin optimizated for external controller!!
-BIG BONT FOR THE TRAK NAME AND AUTORS
-BIG BROWSER
-NO MORE TOYS UNUSEFUL
-IN THE PLAYER ARE SO IMPORTANT: PLAY, CUE STOP, BAND, PITCH, MATCH, CUE POSITION
-RESOLUTION 1024*768 BECAUSE IS THE TIPICAL FOR LAPTOPS
I Think is a good idea the possibility to have A skin with buttons to swicht on or off pannels like
cue, effets, wave display ect...to obtain a modular skin...an user can make the right
configuration for the moment..
-BIG BROWSER
geposted Thu 10 Feb 05 @ 11:52 am
Actually with the used system of skins you can switch off items you don't want but you will always a background. Skins developers can do that but i think they and i prefer waiting for new system of skin where we have "no background" (i mean close a sub-skin ans see the desktop of windows)
geposted Thu 10 Feb 05 @ 2:00 pm
Hey apopsis, euharisto, i'll check it out when it's done.
I have started my own skin, and will build it exactly as i want.
It will be clean, optimized for external use (controller+mixer) so it will have no buttons, no sliders, no crossfader, and nothing that can be controller externaly (what's the point? :)
It WILL have samples, FX etc. which cannot be controlled externaly.
I'm trying to give a professional and futuristic look which is a chalenge... :)
And ofcrouse will share it with the VDJ community! :)
Alex
Alex
geposted Thu 10 Feb 05 @ 4:04 pm
